VATS people, I need your help
A few days ago my security light came on, and now comes on everytime I drive my car. Looking up previous threads led me to believe that my lock cylinder vats was going to die soon, so I decided to do the bypass vats mod.
Well, tonight I took of the panel under the dash and located the wires. I had the proper resistor ready to connect to the vats wires and everything. So I unplugged the wires, and just out of curiosity I tried to start the car..... and it started. So what's going on. Must be that the problem isn't in reading the key from the lock cylinder. Seems like it's maybe the vats computer? What gives? I shouldn't be able to start the car with the vats harness not even connected....
thats understandable, but still without putting the resistor in and disconnecting the wires, it should NOT start at all, right?
If the security light was still on maybe BCM is in "fault enable mode", saw a good reading when it failed, with the car running. Did the light go off after bypassing it?
