Sponsored by: CARiD
Adjusting the stock tachometer
Old Mar 27, 2009 | 06:52 PM
Eiyse98ls1's Avatar
Originally Posted by wssix99
If the needle will only move between the 80mph and 90mph positions there must be a bind somewhere. Can you move the needle across the dial with your fingers? How does it behave when you hook the cluster up to the dash?
If the furthest back you can move the needle back to the left is 80 mph, then the needle is probably installed at the wrong position.
well i got it back to 0mph.. i held it so the needle will drop to 0mph while shaking it until it move itself back. at around 30mph it just move right back to omph.
i havent installed it back since im still waiting on led's. also i never pulled the needles off.. i will as soon as the 6LE overlay gets here..
thanks for the help
Old Mar 28, 2009 | 11:39 AM
riceburnerZ28's Avatar
Could this be done to the fuel gauge? After my fuel pump install the needle is horribly off !
Old Mar 28, 2009 | 11:43 AM
Formula413's Avatar
All the needles are removable, just make sure your problem is not a problem with the fuel sender before you adjust the needle.
