Sponsored by: CARiD
replacing T/A headlight motors
Old Mar 16, 2009 | 09:51 PM
xRelapse13's Avatar
Default replacing T/A headlight motors
Search doesn't work and the sticky is about the gear. How would i go about replacing the whole motor? The headlight doesn't make any noise and lights up, just doesn't come up.
Whats the process to swap out the motor?
Old Mar 17, 2009 | 08:35 AM
willinwtx's Avatar
i searched it on google and the first or second link on it had a great walk through video
Old Mar 17, 2009 | 07:42 PM
baldwintpenguin's Avatar
3 bolts hold it in, unplug the electrical connector take out the 3 bolts pop in the new one, done....more or less
Old Mar 17, 2009 | 07:48 PM
therealcreeper's Avatar
the 3rd bolt is a painnnnnn to get to. have some wd-40 or pb blaster to help get the arm off the motor shaft. pretty straight forward. took about an hour for both the first time for me with no directions just guessing.
Old Mar 17, 2009 | 08:05 PM
xRelapse13's Avatar
thanks alot
Old Mar 18, 2009 | 07:47 AM
bboyferal's Avatar
Yup, like therealcreeper said, the only problems you'll run into are the 3rd bolt (it's a bitch), and the damn shaft might be stuck on there really good. I had to hammer the **** out of mine, and then bend it back into shape!
Then when you do the other side, it will be WAY easier than the first!
Old Mar 18, 2009 | 05:40 PM
Danny2tek's Avatar
You are aware that in order to change the gear you have to remove the motor? The sticky has a link on how to remove the motor in order to replace the gear.
Old Mar 18, 2009 | 06:48 PM
xRelapse13's Avatar
^^^ oh wow, now i really feel stupid. Thanks
Old Apr 24, 2009 | 04:46 AM
73AMX's Avatar
If my headlights lights wont popup should i try to replace the gear or the motor first
Old Apr 24, 2009 | 05:13 AM
Joshiedoom's Avatar
If both of them wont popup the module might be fried.
