does this sound like VATS ?
well I went I stoped for fuel and then when I went and try to start it nothing
I put a new battery and cables about 2 years ago, well I tryed a couple of trys, the dash light goes on and I even see the sercurity light goes on to but nothing when you turn the key well I sat for a few minutes ( called AAA ) I went and hit the battery and check the connections ( everything looked good ) well I went in and turned the key and it started :-)
after I got to work I turned it off and started it a few times and no problem it stated everytime..
does that sound like the VATS ?
all the dash lights turn on but no click from the starter or anything....
thanks guys.
So that is probably the problem.
It seems like this is a common problem.
