Sponsored by: CARiD
Checking Oil
Old Mar 22, 2009 | 03:23 PM
CobraKilla2000's Avatar
Default Checking Oil
What is the best way to check the Oil in my 00' LS1 ? I have heard many different theories on this due to the oil pump. How long after I add oil will the dipstick show me the true reading ? Due I need to leave the car turned off for a certain amount of time before checking it 2 get a true reading ?
Old Mar 22, 2009 | 04:51 PM
Silver98Formula79's Avatar
The owners manual says to check the oil when the engine is warm, drive it some were let it sit for a few mins then check the oil level. If it is just at or below the operating range it could take a quart it get it in the middle of the xxxxxx's....
Old Mar 22, 2009 | 05:46 PM
waldershrek's Avatar
I don't think there is a set limit. Like like a minute or two should be more than enough
Old Mar 22, 2009 | 09:41 PM
LS6427's Avatar
Next time you do an oil change and you put 5.5 quarts back in, let the engine cool down 100%, take the dipstick out and file a little mark at the full level. Then from that day forward only check the oil when its dead cold and you'll have a 100% accurate reading.
I have 3 marks I made on mine for 1,2,3 quarts low.
Put just 3.5 quarts of new oil in, make a mark, then add another and make a mark, then add the last quart and make a mark.
Done.
Old Mar 22, 2009 | 10:10 PM
Done.
Great Idea. Just 1 other question. I am using a Mobile1 oil filter M1-206. I have read it holds an extra 1/4 quart of oil. Should I be refilling with 5.75 quarts of new oil or stick with the 5.5 quarts as specs call for ?
Old Mar 22, 2009 | 10:32 PM
.25 quarts should not hurt if it is a bigger filter.... I dont have any experience with the m1-206. If it is bigger than stock do it.
Old Mar 22, 2009 | 11:04 PM
LS6427's Avatar
Well, for years now I've been putting all 6 quarts in at every oil change. That extra 3/4 of a quart makes no difference and its there as oil burns anyway. But yes, you might as well throw that 3/4 of a quart in too now. All 6.
Old Mar 24, 2009 | 01:51 AM
tripps's Avatar
Just turn the car on for a minute then turn it off. The only reason for turning it on is to get oil in the oil filter. Once it's in there the level should be constant.
Old Mar 24, 2009 | 11:20 AM
NonGoggleGuy's Avatar
You should always drain the oil when it's warm, first of all. After pulling the plug & filter, I always refill with 6 qts. I know the book says 5.5 and part stores tell you 5.5, but it's closer to 6 after a full, clean drain.
As far as checking oil, the car should be cool. Pull the dipstick. Letting it cool lets most of the oil drain from the heads back into the pan. This is a more accurate level check, as well as the reason that A FULL DRAIN is closer to 6 qts. after the valvetrain empties itself.
Old Mar 24, 2009 | 11:39 AM
99T/A_Marine's Avatar
Done.
That's a really good idea. Can't believe i never though of this.
Old Mar 24, 2009 | 12:06 PM
Golf&GM's Avatar
This kind of goes without saying, but I'll say it because no one else has yet. Always check oil with the car parked on LEVEL ground. If you park on a hill it's gonna be off from what it really it.
Old Mar 24, 2009 | 12:29 PM
And make sure the car isn't upside-down.
Old Mar 24, 2009 | 02:52 PM
LS6427's Avatar
Yea, there's just some things where people give 100 different ways that they say is the correct way to check something. Even the manufacturer is wrong sometimes.
This way is 100% accurate every time. Cold check with your own marks on the dipstick.
And if for some reason you want to pull over when its hot and check it, the level will end up somewhere between the marks you made on the dipstick, so you can very accurately know whats in the engine. There's gonna be some, maybe a 1/2-3/4 of a quart, that will take a little bit to drain back into the pan, so just add 1/2-3/4 of a quart to whatever it reads.
