Trouble with bucking/stalling.. AGAIN, please help
https://ls1tech.com/forums/general-m...ng-advice.html
Anyway I changed the spark plugs on 1-11-09 and it seemed to fix the problem... Yesterday, i installed my amp and sub I got from a member on here. A small 300 watt amp and a MTX thunder form stealth box. I hooked everything up and it worked so I went inside for the night.
Now this morning on my way to work, my car is acting just like it did with the fouled plugs... what gives?
could the plugs be fouled again already?? I used the highest AC Delco brand... couldnt get my hands on the NGK 55s... could it be my amp messing something up? I checked the amp power light when the car is off and the amp is off so it shouldnt be using any power right? Trending Topics
Is this something I can replace/fix myself? cause the shop is wanting 1000$ just for parts and then like some crazy $/hr...
thanks
oh what is the CKP sysem variation procedure and the Idle Learn procedure? I cant get the links to work on the website..
