Sponsored by: CARiD
Engine vibration?
Old Oct 27, 2003 | 08:35 PM
1ORANGEWS6's Avatar
Default Engine vibration?
I was sitting waiting for the light to change and I felt the car shake. I looked at the tach to see if the RPMs were changing but they weren't. I got home and popped the hood and twisted the throttle a little and held it to probably about 1200-1300 rpms. The engine started to shake and and the only thing I could guess that would be the problem would be the plugs. I changed them out about a month ago. I also noticed that it uses more gas than it use to. I checked to make sure the plug wire were seated all the way and they felt like they were. Anybody have this problem?
Old Oct 27, 2003 | 08:50 PM
SSEUL8R's Avatar
Mine does the EXACT same thing. It seems out of balance or something around 1200-1400 or so. I'm not sure what makes it do that, but like you, I would really like to know.
Old Oct 31, 2003 | 08:39 PM
WOT's Avatar
WOT
does the shaking go away with no loss of power once rpms climb?
Old Oct 31, 2003 | 09:48 PM
AmMscl's Avatar
Mine too!
My TA sounds and feels like crap below 2000 RPMs, But is solid after that.
Of course I have the piston slap(noise) too.
Old Nov 1, 2003 | 12:45 PM
Camaro2SS1's Avatar
Mine does that too. With the piston slap noise and a small tic that comes and goes. Shop has told me these engines have noisy valvetrains and that the "shake" at low RPM's is normal. Whether I believe them is a different story.
Old Nov 1, 2003 | 03:23 PM
DONAIMIAN's Avatar
Just get a cam. Then youll know what the shake is comming from
