Auburn or Torsen rear?
I have a '99 SS and I was told some either came with an Auburn rear or Torsen rear. I was also told that one of them can't take synthetic 75w90 fluid. I snapped a few pics of my rear too because I think it might be leaking so let me know what you guys think.
![Name: undercar004.jpg
Size: 92.5 KB](https://ls1tech.com/forums/attachments/general-maintenance-repairs/666650d1501791986-auburn-torsen-rear-undercar004.jpg)
![Name: undercar005.jpg
Size: 83.4 KB](https://ls1tech.com/forums/attachments/general-maintenance-repairs/666651d1501791986-auburn-torsen-rear-undercar005.jpg)
98 had auburns standard and other years were optional. Imo the torsen is a bit better even tho its a tad weaker. Theres no clutches to wear out, the torsen uses worm gears, and if you go wirth big tires and wheels the clutches in the auburn will wear out even quicker. Sadly you cant tell without taking the cover off as to which one you have. When looking at the diff an auburn will have springs in the carrier and a torsen will have screw like gears.
I dont see one unless its leaking from the front pinion. When you seal the cover back up just rtv hi temp silicone and forget the gasket. Its cheaper easier and I've never had it leak.
Btw heres some links to an auburn and torsen pic the auburn is the one with springs inside.
http://216.77.188.54/coDataImages/p/...60/zexel50.jpg
http://www.riversidegear.com/categor...20Aub%2028.jpg
I have an Auburn, I think if it wears out I will probably switch to a Torsen, they can have problems but at least there is nothing that will wear out by design.
It doesn't look like you have much seepage in those pics, mine seems to have quite a bit of seepage, but the level is fine when I check it, right up to the fill plug.
the torsen, because it does not have frictional clutches like the auburn, does not require the limited-slip additive (a.k.a. friction modifier) to the gear oil. Any oil will work with the torsen, the requirement for a GL-5 "gear" oil is based on the ring & pinion gear, so any gear oil meeting GL-5 will work fine- conventional, blend, or synthetic, high-end brands like redline, royal purple all the way down to cheapo store brands. With the torsen friction modifier is used, or was used in the factory fill, because it helps to reduce overall noise; in slow tight turns the torsen can be noisy and the friction modifier helps prevent this; i've used mineral gear oil in mine with no additive and never noticed differential noise so i don't know how likely it is to happen. But the noise does not hurt anything, it is just a normal operating noise, and you can read about this on the zexel-torsen website
http://www.torsen.com/general/genera...%20rear%20axle
http://www.auburngear.com/aftermarke...6pagesize%3d20
The auburn can take synthetic, you won't hurt it. It is more of a recommendation not a requirement. What seems to happen when using synthetic or so is claimed is that the clutches don't hold as well, or slip easier, causing you lose some torque transfer capability. Worst case being a one-wheel burnout, in which case if you continue to do a one-wheel burnout you're just slipping and wearing the differential clutches.
The Auburn Gear limited-slip differential design has been extensively tested with high quality non-synthetic 80W90 hypoid oils treated with GM or Ford friction additives (3 oz. of additive will treat 1 quart of oil). To avoid differential clutch chatter (noise) and for optimum performance, use the oil and additive described above. Use of other additive and oil types may cause differential clutch chatter.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
no, if anything it'll save you money. the recommended oil is 80w-90 mineral bases non-synthetic gear oil that meets GL-5. I would just pick up the cheapest mineral gear oil from the parts store, as long as it says GL-5 on the bottle your good. And if the store doesnt specifically have 80w90 don't go hunting from store to store, 75w90 is fine.
