Sponsored by: CARiD
Camaro throwing code P0332?
Old Jun 8, 2009 | 08:15 PM
BlueBeastSS's Avatar
Default Camaro throwing code P0332?
I have an 01 Camaro SS and its throwing the code P0332 What can i do to fix that?
Old Jun 8, 2009 | 10:20 PM
Camaro8509's Avatar
People should really try google first.... There are a million answers to your question on there, here is one which i found simply by typing camaro code po332 into google.
CLICK HERE
Old Jun 8, 2009 | 11:54 PM
LS1_K1DD's Avatar
https://ls1tech.com/forums/automatic...lush-more.html
There ya go man. Bookmark this link. Has all the codes you'll ever need to look up and is very well put together.
Old Jun 8, 2009 | 11:55 PM
LS1_K1DD's Avatar
P0332 - Knock Sensor 2 Circuit Low Input (Bank 2)
Thats what your code means. I've never delt with knock sensors but call a local parts store, replace it, and clear your code. Should do the trick. - Zack
PS- Bank 2 means on the passenger side. Hope this helps.
Old Jun 9, 2009 | 05:59 PM
Where is the sensor located at, and is it hard to change out?
Old Jun 9, 2009 | 08:54 PM
LS1_K1DD's Avatar
^Wont be hard to change. Search on here im sure someone has a diagram.
Old Jun 9, 2009 | 11:24 PM
question's Avatar
Knock sensors are located under the intake manifold. There is two of them. Even if only one is bad I recommend changing both while you are under there.
Old Jun 10, 2009 | 11:13 AM
mikenews's Avatar
+1 on that, you gotta pull the intake...you should put in a cam in to while you are at it...lol
Old Jun 11, 2009 | 10:59 AM
alright guys really appreciate it thanks
Old Apr 21, 2011 | 02:27 AM
TorqueAutoMotiv's Avatar
This code just popped on mine tonight. Hmmm ohwell looks like im pulling the intake mani then
