Sponsored by: CARiD
Park Brake Cable Adjustment
Old Jun 13, 2009 | 03:38 PM
Camaro98Z/28's Avatar
Default Park Brake Cable Adjustment
How do you tighten the ebrake cable.
I have to have my handle FULLY UP for it to make any effect at locking the rear wheels.
Thanks guys!
Old Jun 13, 2009 | 03:47 PM
02 35thLE's Avatar
It's a self adjusting system so you can't manually adjust. Your parking brake shoes may be worn out.
Old Jun 13, 2009 | 03:51 PM
Just had the rears off when replacing the rotors, they were fine
Old Jun 13, 2009 | 10:38 PM
V8Z28s's Avatar
Default pretty sure
i'm not positive but i havn't been under ls1 but lt1 and third gens are this way. it should be half way to 3/4 down to back of car but just follow the e brake cable and there should be a nut on a long kind of hollow tube with threads and you tighten to take slack out.
Old Jun 14, 2009 | 05:56 PM
billyb's Avatar
remove wheel
remove rotor
small thumb wheel @ top of brake plate
adjusting will spread round emerg brake shoe type
ck adj the rotor will fit back on,
there is no cable adjustment
hope this helps.
Old Jul 24, 2009 | 11:07 PM
cryptnosis's Avatar
which rotor? drivers side rear i take it? And what tools are required please. thanks
Old Jul 25, 2009 | 08:03 AM
jcws6's Avatar
You'll need to remove BOTH rear rotors. Each side has an adjuster screw. You'll want to adjust the screw until the shoes don't drag when the rotor is on & you spin it. Actual clearance from the rotor drum to the shoe is 0.026", so it should be adjusted to the point where the rotors just barely don't drag, if that makes sense.
Old Jul 25, 2009 | 12:43 PM
wssix99's Avatar
Save the manuals!
Post # 6 in the following thread has the procedure from the factory manual with regard to measuring play in the brakes: https://ls1tech.com/forums/suspensio...ightening.html
