Soo, A/C compressor turns on, then off
So I got my car back from the body shop the other day, and now all of a sudden the a/c isn't working. It worked fine on the drive home from the shop, but after I turned it off and restarted it about an hour later, I noticed that the a/c was blowin hot air. I turned off the radio and listened and you can hear tell the compressor turns on, it stays on for just a few seconds, and then cuts back off.
I assumed it was just low on refrigerant. I went to add some, and it reads full. The fan that I believe is supposed to turn on when your a/c turns on isn't turning on. What could cause this to happen? I checked all m fuses and everything seems fine, the fan for the engine coolant is worknig, but not the one for the a/c.
Somebody give me some advice please!!!! I live in Texas and it is summer now, wayyyyyy to damn hot to not have an a/c.
yea usually when it does that it means that the freon is low. Could it be a bad low pressure switch. What all did the body shop mess with. Could shed some light on your problem.
I was thinking it may be the low pressure switch, but would that cause the fan to not turn on? When i hooked the gauge up to it, it said that if the psi was in the green, it meant add freon, it said if it read yellow, that it could be a possible overcharge, and if it went into the red it could possibly have a mechanical problem. The gauge jumps to the red every time. If it is the low pressure switch, how would I fix it? I have heard it's not expensive, but I don't know how to replace it.
That is what it does when the system pressure is low like choppers said. It turns off and on to try and regain pressure. The shop may have damaged a hose and it is leaking would be my guess. Go get a pressure gauge from a parts store and see what it reads.
It says on the directions for the gauge that it is calibrated to read the psi when it is between 75-85 degrees. I checked it when it was about 103 or so degrees, but would it really throw it off that much?
Or do you guys think I should just bite the bullet and take it to a mechanic?
Am I possibly doing it wrong?
no. the low pressure on a hot day needs to be around 35-45. i always run 45 in mine when its 100 degrees out. Says it 75-80 i run 37 psi. If you over charge a a/c system most of the time water won't drip from it and it never gets really cold. If its to low the lines will freeze up(most of the time). I think your looking at a high pressure gauge instead of the low pressure one.
Well guys, I feel like a dumbass but at the same time, I have discovered another problem. I was checking my fuses and everything about 1:30 this morning, and I found a fuse that was blown out. It was a 40 amp that said it was for the cool fan.
Well, I drove to wal-mart, cuz that is the only place open around here that time of night, and the only set of 40 amp fuses came in a big *** box that was 25$. Well, i get home swap the fuse and everything turns on, and i'm all smiles........POP, little spark, and there goes that new fuse I had just put in.
Needless to say I was pissed, I replaced that bitch with a 50 amp, which worked for just about as long as the 40 amp when it popped as well. I was just about ready to shoot somebody when I decided **** it and put a 30 amp fuse in.
It is still working, and I have had the a/c running and the coolant fan is working and everything. I know it's more than likely just a temporary fix to the real under-lying problem, but oh well I am happy for now.
