Sponsored by: CARiD
Yellow plugs - Pics inside
Old Jun 25, 2009 | 03:03 PM
MiniTransAm's Avatar
Default Yellow plugs - Pics inside
Hey guys.
Noticed the other day that I had a hesitation when the motor was cold around 2000 rpms or so. I had recently replaced the plugs with NGK TR55 copper plugs. I believe I also got colder than stock plugs as was recommended in a thread on here. Hell if I can find the thread now though. The gap on all of them was around .038
When I pulled the passenger side plugs, they looked fine. Looked like a normal used plug. However the driver side, they ALL had yellow on the electrode(?) of the plug. What could cause this discoloroation? Is is at all possible I've got a goofy 02 sensor for that side which could have the car running rich/lean?
Here's the pics. Left plug was from the passenger side and is what all 4 looked like. Right side is from driver side and all 4 looked this way.
Old Jun 25, 2009 | 03:35 PM
LS6427's Avatar
02 sensor probably isn't operating properly. You won;t necessarily get a code until it fails.
Replace it with a Denso.
Old Jun 25, 2009 | 07:10 PM
99RTA's Avatar
What color is the coolant in your car? Its possible a little is getting in that cylinder.
Old Jun 25, 2009 | 08:18 PM
I believe it's dexcool. All 4 cylinders on that side of the engine looked that way. Gonna replace the O2 sensors tomorrow and see what happens.
Old Jun 25, 2009 | 08:48 PM
LS6427's Avatar
Its not coolant getting in. If it were getting into all 4 on that side you'd have major overheating issues too, with coolant boiling over.
Old Jun 25, 2009 | 08:52 PM
I hope I don't get screwed but I'm going to put Bosch plugs in tomorrow. My father in law works at carquest and he can get me stuff for crazy cheap. Hopefully I get lucky with them. If not, I'll try to find some denso's or order some Delco's off GM parts direct.
Old Jun 25, 2009 | 09:02 PM
LS6427's Avatar
Don;t waste your time with Bosch. Also, AC Delco 02 sensors are now Densos.
I believe Densos are like $39.00 here: www.rockauto.com
Part # 2344087 and #2344025
Old Jun 25, 2009 | 10:03 PM
Denso's website says you can buy them at Carquest so I'll check into it when I go up there. Were going to the beach and taking that car on Saturday so unfortunately I can't wait for any to be shipped to me. Cross your fingers for me.
