Sponsored by: CARiD
O2 sensor issues...question
Old Jul 8, 2009 | 07:56 PM
Blackhawk777's Avatar
Default O2 sensor issues...question
I know I've gotten codes P0162 and P1416 before on the car, so I know I probably need new sensors, but would those going a bit haywire and off make my car feel completely gutless and like I'm driving a 4 cylinder??? I hammer on it on highways and it just feels like I'm free revving with little to know acceleration...wtf?
Old Jul 8, 2009 | 08:07 PM
LS6427's Avatar
Thats exactly what failing 02 sensors do.
And stop stomping the gas pedal when its running like that. Misfires and stumbling can damage your engine at high rpm.s
New 02 sensors...$40.00....Densos.....www.rockauto.com
Old Jul 8, 2009 | 08:08 PM
yeah it felt sluggish before I got the codes showing up, and I use rock auto alot. They sponsor a local car club my wife is in and gets free shipping with a small discount
I'll probably go that route.
Old Jul 8, 2009 | 09:12 PM
LS6427's Avatar
Failing 02 sensors won't show any codes or an SES light until they totally fail or until they are really making the engine run horribly.
And make sure you buy Densos. If you buy AC Delcos you will most likely get Densos in the box and pay double or triple. GM uses Densos now for their 02 sensors.
And Densos are a better 02 sensor than GM makes.
Old Jul 10, 2009 | 12:37 AM
SlideRight's Avatar
i had a failing O2 and it started making my mixture ridiculously rich =/ Replaced it and now problem free....ish
Old Jul 10, 2009 | 09:37 PM
Yup my mix has been getting richer and richer as of late. My exhaust tips look like it's a diesel right now from being so pig rich.
Old Jul 10, 2009 | 09:45 PM
eX-DZ28's Avatar
Would the Denso's also be a good replacement for an LT1 car? I checked and they are indeed half what the delcos cost wich would be nice.
sorry to lol
Old Jul 11, 2009 | 08:30 PM
Ok, so do I need any special tools or will just some big *** wrenches and pb blaster do the job? I want to get this done ASAP.
Old Jul 11, 2009 | 09:01 PM
Danny2tek's Avatar
If you have headers I would go with the Vettes O2 sensors.
Old Jul 11, 2009 | 09:09 PM
no headers, but I still need to know if I can just use a regular wrench or if I need a special one.
Old Jul 11, 2009 | 09:10 PM
Danny2tek's Avatar
I used an adjustable wrench
Old Jul 12, 2009 | 12:45 PM
Works for me then
Old Jul 12, 2009 | 10:53 PM
LS6427's Avatar
One crescent wrench is all you need, they come out with ease.
And Vette 02 sensors are the Densos.
Old Jul 13, 2009 | 01:06 PM
SlideRight's Avatar
Whats up w/ the Densos O2 sensors? Do they not go bad as often or something?
Old Jul 13, 2009 | 01:14 PM
LS6427's Avatar
The open slits that the GM and Bosch 02 sensors use to capture exhaust as its flows over them is just about the dumbest design ever. Only 2-3 of the slits gets direct flow of exhaust right into them. The others get exhaust flowing over the remaining 3-4 slits and they don;t catch exhaust as it flows by.
The Densos have holes all oround the tip of the sensor, it catches alot more exhaust as it flows by, getting a more accurate sample.
Its just the way it should be made. Slits make no sense at all.
Old Jul 13, 2009 | 08:25 PM
Yeah I saw the rockauto link. The densos will go on, but I'm not overly sure which ones to get?
Old Jul 13, 2009 | 09:29 PM
MiniTransAm's Avatar
I bought a long 7/8 wrench from Advanced Auto to use on the driver side. It was a bit too tight over there to use a 02 sensor socket. Passenger side should be easy.
Old Jul 14, 2009 | 12:13 AM
LS6427's Avatar
2344087
2344025
$39.xx each.
*** Just make sure you double check with them on the phone that the lengths are correct for which sensors you need, thats the only reason the part numbers are different.
Old Jul 14, 2009 | 01:29 PM
SlideRight's Avatar
ohh, ok, thanks for the info on the sensors. Are those other ones cheaper than the stock ones also?
Old Jul 14, 2009 | 01:55 PM
LS6427's Avatar
Hell yeah. Densos are $40.00 each.
GM AC Delcos at the dealerships are as high as $150.00 each.
BUT...........GM now uses Densos as their own AC Delco sensors. If you go to any auto parts store or to the dealership and you buy AC Delso 02 sensors....you will open the AC Delco box and you will have Denso sensors in there.
This happened to me earlier this year at Bennett Auto. Opened the boxes at the counter and found Densos inside. I told the guy to go grab a box of Densos so I can look at them and the sensors were 100% identical in every way. But SCUMBAG "GM" was charging $130.00 per plug through Bennett. The Densos were like $60.00 each IIRC.
So of course I bought the Densos. And my friend who is a manager of a parts department at a Pontiac dealership confirmed that GM is using them now.
Densos are $39.xx each through www.rockauto.com GM is just a bunch of dirtbag rip-off artists. Thats why GM is going down the toilet, the entire company is **** and the people who work there are spoiled, over-paid cry babies. Bye-Bye GM.
