'93 T/A running hot
Take the radiator cap off while its cold, top off the coolant, start the engine and stand there and wait for the engine to warm up. After you see your temp guage start to rise you want to squeeze the upper and lower radiator hoses rapidly about 10-20 times each, alternating back and forth from hose to hose. This will pulsate the air and water thats standing in front of the t-stat. Problem is, the air bubble is up against the t-stat and not the water, so it won't open because the water is whats getting hot. So by pulsating and pushing the water throguh the system it will move the air bubble around.
That should get the t-stat to open. Once it finally starts to flow and the coolant drops down, just top it off quickly while the t-stat is still open and keep topping it off till the flow stops.
That should do it.
***sometimes it can take a long time. if it gets too hot and it hasen't opened yet, shut the engine off, then restart it and keep trying.
You know the pump is bad when it starts leaking out the weep hole.
Did the coolant drop down ever?
If the coolant did nothing.....your t-stat is not opening...period.
If it did flow and you still overheat after you put the radiator cap on and go for a drive....it can be a dizen different things.
If you don't verify if the coolant is flowing.....you will never figure anything out.
The fans........they will turn on regardless of what the t-ststa is doing, the fans work off the coolant temp sensor in the head. If your fans are NEVER coming on no matter what...you found your problem.
Are there any "vents" that look like bleeders off the radiator? I had the car towed to the shop when the ignition module went. They said "all these bleeders were open all over the radiator and you had no coolant at all so we closed all the bleeders." Well, no one had touched any bleeders and the reason I had no coolant - which I told them - was because we had just replaced a lower hose and lost most of the coolant.
If it doesn't, get a new t-stat.
230 degrees is pretty damn hot. But don't go by the guage in the cluster, they're not at all accurate. I don't know much about LT1's but I would think your fans are supposed to come on around 215* of so.
