Rear calipers make clicking noise???
be careful it may be your bracket bolts that cold the caliper onto the diff it happened to me once ON THE FREEWAY super scary double check its not that . you should be able to jiggle the caliper to see if thats the case if not check you caliper pins
I wiggled the calipers and they didn't budge. They dont make the noise when I spin the tires when its on jack stands.
I dont know for sure that it is the calipers but the noise stops when I press the brakes. It pulls to the right but it needs an alignment and new tires.
It's the same problem I have, the anti-rattle clips in the calipers aren't doing their job, and they're letting the calipers rattle...I recently replaced my pads and they didn't come with new clips, and I can't figure out where to buy the stupid things...worst part is they're probably only going to cost like...$1 each if I can ever manage to find where to buy them.
No I don't think its every rotation. You can hear it click at every speed.
There isn't a rock in my tire. Its much louder than that. Plus there isn't enough tread on my tires to have a rock in them, lol.
I will look into these anti rattle clips. Do you have a pic?
