Going down the check list...??
Could be corrossion, could be bad "excitor wire"...
It takes all the wires and cables out of the loop when you test it off the car, if the alternator is good thats all you'll know. If you test it on the car with the engine running and you don't get a good reading, you'll pretty much know its a cable or wire.....which seems to be your problem anyway.
An alternator doesn't produce any juice at all just because it spins. It has to have a small voltage signal present from the battery to make it play, and that's what the exciter wire provides.
The car acts funny at a stop light because the voltage is so low. Computers don't like that very much.
