Sponsored by: CARiD
oil presure switch
Old Aug 10, 2009 | 02:50 PM
ricardo colon's Avatar
Default oil presure switch
in the past 20 month i changed the oil presure switch 3 times , what can the problem be ,
Old Aug 10, 2009 | 08:54 PM
fleetmgr's Avatar
Can you give a more detailed description of the problem?
Old Aug 11, 2009 | 09:45 AM
in the past 20 months i changed the oil presure switch because it busrt and lost a quart of oil , my car is a1997 firebird 3.8 engine , i notice that the presure switch for the 5.7 and 3.8 looks the same.
Old Aug 11, 2009 | 10:56 AM
fleetmgr's Avatar
Most oil pressure switches look the same, regardless of make or model. Make sure it's the right part number for starters.
What problems are you seeing with the replacements?
Old Aug 11, 2009 | 11:28 AM
presure over 70 psi in cold starts, going see if i can find the original part.
Old Aug 12, 2009 | 12:48 PM
cambirdracing's Avatar
My 94 3.4 pumps 70 most of the time. Except hot at idle. Then it's about 40. And this thing has 242,000 miles on it.
Old Aug 12, 2009 | 04:30 PM
thinking about putting a larger filter , anybody know the part number for a 1997 firebird 3.8 engine
Old Aug 15, 2009 | 01:40 PM
fix the problem , got the original part , everything back to normal , thanks
Old Aug 15, 2009 | 01:53 PM
venom346's Avatar
Glad to hear asll went well
