Sponsored by: CARiD
A/C Question
Old Aug 22, 2009 | 09:03 PM
fleetmgr's Avatar
Originally Posted by dragonrage
Guys, please don't call it Freon, because it's not. R134a it is.
Only if you promise to never call another vacuum bottle a Thermos unless made by them.
It is correctly called Freon if it's made by DuPont.
If you really want to be picky, we could all call it 1,1,1,2-Tetrafluoroethane.
Old Aug 24, 2009 | 08:06 PM
RUTI'S WS6 TA's Avatar
Originally Posted by fleetmgr
The HP and LP switches are in the back side of the compressor. If you look there, you'll see a pair of wire connectors, one on each switch. You'll have to look in a book to see which is which. The switches are held in by snap rings, and have an oring around them to seal. About $25 ea. at NAPA.
Thanks - I'll give this a try and see if that works.
Old Aug 25, 2009 | 08:48 AM
fleetmgr's Avatar
Don't try to change the switches with freon in the system!!!!!
Old Aug 25, 2009 | 11:06 AM
Thanks for the warning. Maybe it's best I bring it in to be checked.
Old Aug 25, 2009 | 12:11 PM
jimmyblue's Avatar
Moderator
Are there these switches on all models? Because I
see no hint of them in my schematic set ('02 F-body).
Old Aug 25, 2009 | 01:43 PM
fleetmgr's Avatar
I've never seen an A/C system in or out of a car that didn't have lo/hi pressure switches in my time doing this. Now it could be that all they are is a sensor relaying info to the computer, which inturn is controlling things.
Old Aug 25, 2009 | 04:46 PM
slow's Avatar
These are not on the 98 ls1 compressors.
There is a high pressure sending unit, that has pcm control for both high and low pressure cutoffs thresholds. There may be more inside the cabin, but exterior that was the only sensor when I reinstalled an ac system in a 1998 formula. There is a clutch connector on the compressor.
Ryan
Old Aug 25, 2009 | 11:03 PM
samson_420's Avatar
Ryan
Yeah, that's all there is on my 98' also. . . Other years should be the same. . . I think. One pressure switch sending signal back to the PCM. . . And the clutch wire. . . . . . .
Old Aug 29, 2009 | 11:08 AM
Daredevil_TA's Avatar
R12 or freon 12 is Dichlorodifluoromethane it is NOT compatible with R134a they have similar properties but are NOT the same.
