Sponsored by: CARiD
Whats the problem ?
Old Aug 26, 2009 | 04:06 PM
Jayh's Avatar
Default Whats the problem ?
I have a hesitation or a lack of power as soon as I start engaging the clutch. Then all of a sudden, the car jumps and everythings fine. Its just for an instant, everytime im engaging the clutch. Almost reminds me of a vacuum issue. Car revs fine in neutral. I replace all PCV lines and the valve. EGR is deleted and AIR...Headers, Mild Cam, and FIPK. Any ideas whats causing the initial blaah ?
Old Aug 26, 2009 | 04:39 PM
LS6427's Avatar
Does it happen in every gear while engaging it....or just first to take off?
Old Aug 26, 2009 | 05:59 PM
Jayh's Avatar
Very suttle on other gears....but bad from a stop....I can start with a little rpm and its normal
Old Aug 26, 2009 | 06:11 PM
LS6427's Avatar
Did this just start happening out or nowhere...or was that hesitation getting worse over time?
Sounds like a clutch issue...if it revs fine in nuetral.
Old Aug 26, 2009 | 09:04 PM
Jayh's Avatar
It is just now noticable I guess.....Clutch is 4 Months old......I was letting the RPMs get low as I was driving slowly in 2nd gear earlier and it was struggling to get back to a normal increase in RPM. Its like theres a threshold when everything goes back to normal. Initially, I was having a high Idle; last time, it was a vacuum leak, so this time I replaces the PCV valve, and housing, and ditched my makeshift catch can. I actualy gained noticable horse power and my idle problem is fixed but now im having the bogging down at low rpm.
Old Aug 26, 2009 | 09:09 PM
Jayh's Avatar
And twice, for a split second, its been fluttery with an unresponsive pedal....like a carburator flooding...then it snaps my neck when it straightens out.
Old Aug 28, 2009 | 12:01 PM
Jayh's Avatar
Anybody think its a throttle position sensor...I dont know the symptoms if it is acting up ...
Old Aug 28, 2009 | 12:20 PM
LS6427's Avatar
Well, go get it checked for free for codes. Even if you don't have an SES light.
Old Sep 9, 2009 | 01:41 PM
Jayh's Avatar
Only codes are O2's. In any gear at a low RPM, I can give it gas and the car just flutters like its flooding out. Runs strong at higher RPMS. Last thing I did was replace the PCV Valve before this was really noticable. I also ran a day or so without the MAF plugged in on accident. Ive chased everything...cant figure nothing out.
