Sponsored by: CARiD
burning oil smell after stop and go traffic
Old Aug 30, 2009 | 03:01 PM
blitzace12's Avatar
Default burning oil smell after stop and go traffic
yesterday there was a cruse down a street by my house and after about 1/2 an hour i started to get a burning smell from the front of the car. after i got home it got a little worse and i could smell it outside of the car. everything is acting fine the temp was right at normal could it be a tranny issue (m6) or clutch or something else?
Old Aug 30, 2009 | 03:25 PM
xbcrguy182x's Avatar
Any leaks? Oil could be leaking onto the exhaust and that's how you get that smell.
Old Aug 30, 2009 | 03:37 PM
Stocktonz28's Avatar
1. Your **** could just be dirty
2.Check for blueish exshust. If its blue then you need to replace a leaking head gasket.
(sometimes you can leak oil from your heads into your exshust which will turn your exshust a blueish color)
3. It could be leaking trough your piston rings and into your combustion chamber which is a lil more serious becouse you have to replace piston rings.
(it happens nothing last forever)
those are my 3 guesses in order but rember i could be completly wrong. Clean off your motor real good along with your under carriage if no blue smoke and maybe someone else will have sompthing a little more reasonable then just checking pistons and head gaskets....
Old Aug 30, 2009 | 10:19 PM
dre2013's Avatar
when a headgasket goes out the smoke is almost always white from coolant burning. he said his burning oil smell was coming from the front end, so it sounds like you have a bad valvecover gasket dropping oil on the manifolds, or a rear main seal leak that is dropping oil onto the ypipe
Old Aug 31, 2009 | 09:04 AM
blitzace12's Avatar
hmmm... im not very techical so how much is this going to cost me?
Old Aug 31, 2009 | 09:05 AM
blitzace12's Avatar
is it something that has to be done right now? i am a little low on cash... should i park it?
Old Aug 31, 2009 | 09:27 PM
SavageCamaro96's Avatar
nah, if its just dripping a little keep driving it and remember to check your oil level more often.
Old Aug 31, 2009 | 09:32 PM
SparkyJJO's Avatar
When my oil pan was leaking it would dribble on the Y pipe and burn off, making everything all smelly.
Old Aug 31, 2009 | 10:24 PM
eseibel67's Avatar
Oil filler cap tight?
Old Aug 31, 2009 | 11:30 PM
shtnfrds's Avatar
check your pwr steering hoses as well. mine was leaking at the rack and fluid was getting on the bottom of my headers, it was just like oil burning
Old Sep 1, 2009 | 10:14 AM
mochiba's Avatar
You sure it's oil? I thought my new clucth was going bacause of this bad smell...when I got under there I found a bag wrapped around the exhaust and it was stinking like crazy while it was burning off...
Old Sep 1, 2009 | 11:38 AM
bluestrat's Avatar
+1!
I had this exact same thing happen - When I would be stopped then go I could smell it through the HVAC but not any other time. My power steering pump was on its way out and was leaking on the exhaust. Check that one out, it sounds very similar to what I went through.
Good luck!
