New grind after hitt`n a dip hard
Old 10-12-2009, 11:34 PM
ls1fsho's Avatar
Default New grind after hitt`n a dip hard
yo, man i just punched it about 5k on my new motor, hit the same dip i have before and now it feels like the tranny is humming against the center console, i went under the car and chcked the tranny mount , it seemed fine, after i tightened it all together it was cool for about 10 minutes then it made that grinding sound agin, sounds kinda ilke a threaded screw hav'n someting ride the threads, any idea woudl be much appreciated, i just got a new motor put in, im sure the tranny is coo but now i got this gridn`n sound at low rpm shift`n and i aint even gunna try to punch if kuz im sur eit`'ll get worse. my question is could a torque arm cause this, kuz it seems like it travels from the mid portion to the rear end, thanks for any responses.
Old 10-14-2009, 04:29 PM
Blackhawk777's Avatar
Uhh... What in the blue hell did you just say??? ENGLISH MAN! USE IT!
Old 10-14-2009, 04:58 PM
Rychen's Avatar
sho nuff be puttin on da skidz like yo yo sup ho.
Here's the stone bible for you to collar that apple trickeration that will truly get your boots on! Say all you cats and chicks, don't be icky. Bust your conk on this mess and you'll be wailin' .
Werd.
Old 10-14-2009, 05:39 PM
shtnfrds's Avatar
check to see if you bent your exhaust to the point its rubbing on the floorboards? or roll it off a cliff.....
