Sponsored by: CARiD
interior door crack????
Old Dec 13, 2005 | 08:18 PM
  #161
frisky2101's Avatar
yep I "had" a crack. Got real cold down here a few days back, and BANG the next thing I knew the whole thing had cracked all the way down.... But what can you do
Old Dec 13, 2005 | 08:42 PM
  #162
Cephiros's Avatar
yeha i looekd closer, i can see 2 other places its gonna crack eventually, and ont he other door i see the bowing in all 3 places, i need to take out those door panels andget rid of those damn staples..find soemthing else to attach it with, do pop rivits work as stated or will it eventually lead to the same problem?
Old Dec 13, 2005 | 08:54 PM
  #163
5550racing's Avatar
Yep. Same exact thing happened to my T/A. I went to open the door one day and saw the crack, looked over at the passenger side, there was a crack in it too! and i agree, i think its the cold weather that dad it, not the sun. Thanks for the little write up, thats a big help, now i just got to do it.
Old Dec 15, 2005 | 09:49 PM
  #164
black_bart's Avatar
Originally Posted by 01TAFlyer
Is anyone elses as bad as mine?
Give that man the trophy!!
Old Dec 28, 2005 | 10:36 PM
  #165
99Andrew's Avatar
Default Same crack here!
Our temp. dropped to zero a few weeks ago and my driver's side panel cracked! Thank you GM!
Old Dec 29, 2005 | 12:24 AM
  #166
Roarin_8's Avatar
That sucks, I've never had that crack when I had the T/A but I also always covered it. The camaro has leather at that spot so it has no problems flexing with the cold or heat.
Old Dec 29, 2005 | 12:51 AM
  #167
Cephiros's Avatar
theres an idea, i wonder what it wodul look liek it you covered that part of the panel in leather.
Old Dec 31, 2005 | 01:10 PM
  #168
LTSpeed's Avatar
Got this same crack on the 99 Firebird (both doors). The 97 Camaro doesn't have it. Both have been exposed to the same conditions.
Old Jan 4, 2006 | 09:30 PM
  #169
DogNutz's Avatar
BOTH doors here as well! Both mine are as bad as pictured above and both happened in wintertime! This must be MUCH more common then we first thought.
Old Jan 4, 2006 | 09:42 PM
  #170
2001 White Ws6's Avatar
Ahh **** i was wondering where my inch long crack on the driver's side door came from. It seems to get larger over time. Also when i look at the same area on the pass. side you can sorta see a stressed area...hard to notice but i'll try to get pics of it tomorrow.
Old Jan 5, 2006 | 01:32 PM
  #171
The Sad's Avatar
I just did the fix above where you take out the staples, then glue and re-attach. It worked pretty well.
Old Jan 5, 2006 | 03:29 PM
  #172
john shea's Avatar
I have the same interior door cracks pictured just thought
I'd throw my .02 in with everyone.
Old Jan 11, 2006 | 12:28 AM
  #173
SprFly99TA's Avatar
I have the same crack...and its on both door panels. My car is in storage for winter and I went and started it up yesterday and noticed that the entire top or the drivers side door panel is faded like plastic does when it is stressed....it's a real eye sore.
Old Mar 14, 2006 | 05:46 PM
  #174
tom30ta's Avatar
I just got a crack on the passenger side of my 30th TA. I am sooo pissed off. Does anyone know if I could buy a used door with grey leather and then replace the grey leather with the white leather off my cracked door?
Old Mar 15, 2006 | 08:33 AM
  #175
OnA Fan's Avatar
Is this only on LS1 cars or am I just one of the lucky ones?
Since I'm putting in leather, I was going to look for a set with leather inserts and the Monsoon speaker set-up but now I think I'll just re-cover the cloth inserts with vinyl and not chance getting panels that will crack.
Old Mar 17, 2006 | 01:06 AM
  #176
fenix99's Avatar
Restricted User
i think this happpens on all 3rd 4th gen fbody firebird/trans ams, not camaro's becuz they have diff. panels...but dam wutta piece of crap...i thought mine was kind of rare cuz it never had this...but then my friends door cracked and now my pass. side panel created a crack. Eff'ing sucks wheres the crazy glue ****
Old Mar 30, 2006 | 07:05 PM
  #177
waldonga's Avatar
Default Crack
I just bought a 2000 WS6 last month and it has that same crack on the passenger side of the car! It has tan interior so you can't say it is just the dark colors. I have had a 95 formula and a 97 WS6 and never had this problem before!!
Old Mar 30, 2006 | 08:18 PM
  #178
JL ws-6's Avatar
Race your car!
I just noticed mine on the drivers side... looks just like the pic above of the one that's broken all the way thru. This is a factory problem... not sure what it takes for a recall to get started, but one should be for this. I'll bet for every person on here that has mentioned the crack, there's 50 that have it that haven't.
Old Mar 30, 2006 | 08:38 PM
  #179
Randy WS6's Avatar
I have a 2000WS6 and both doors are cracked. GM
Old Mar 31, 2006 | 05:11 AM
  #180
JL ws-6's Avatar
Race your car!
I guess when I go to pull my stereo out for weight reduction, and pull the door bars, I have another project to go along with it..... figureing out a way to screw/pop rivit that rubber molding onto the door, and epoxy up the crack. I just hope I get to it before both sides crack, or the drivers side gets any worse.
