Lumbar leaks and Sail panels popping off
Does anyone know how to figure out where the air would be leaking on the power lumbar or is there a commom leak spot? Mine will not hold. This is my second t/a and is the second one to do it. Also my sail panels keep popping loose and rattle is there a way to get them to fit better?
Yeah mine does that too the previous owner popped it with his fat ***. It's leaking from the side bolsters somewhere and I know replacement seats are hard to come by, my interior needs a little help
Save the manuals!
The sail panel problem is related to TSB#: 00-08-110-004 This thread has the details: https://ls1tech.com/forums/general-m...rior-trim.html
Thanks that makes sense on the sail panels. I will probably do this when i do the fix on the door panels. As far as the seats i am thinking it may be a check valve on the pump it self because neither seat will hold. I will let yall know if i find anything.
