did i get screwed??
Also check on the drivers side frame rail. There is a ground strap that runs from the harness to the frame, it will be grounded right by the brake lines.
Also check the ground from the battery on the passenger side shock tower. Make sure that it's nice and tight.
Then check your battery connections to make sure they're on tight and no corrosion.
