did i get screwed??
any help is appreciated thanks, Nate
I hope you got a hell of a deal on this lemon. You really need to go through everything. I strongly doubt that it is one this that is fucked up. Blinking SES light is quite bad. It typically means that there is a fairly serious malfunction.
The only time I have seen one is when I put low impedance injectors in a car that car with high impedance ones.
Like said, do a complete tune up. New o2's, plugs, wires, oil and oil filter. Get some spray electronics cleaner and clean the maf wires. Be careful not to damage them. I use a q-tip as well.
Afterwards see how it runs. If after a tune up it doesn't get better, post up. It could be a few other things.
I suggest you take a look at your maf or coils. Flashing SES light is indicative of a misfire. A defective maf would cause the car to die down, and prevent you from revving. A defective coil would cause a backfire. It could also be a random misfire, which is one of the worst codes, because it doesn't point you in any particular direction.
I just reread your post and noticed the 'electrical' issues. Now I suggest you check the connector at the ecu.
