Need advice for how to fix PCV line vacuum leak
Old 12-12-2009, 01:57 PM
Tuffguy610's Avatar
Default Need advice for how to fix PCV line vacuum leak
Hey all,
I have been driving my car around as a weekend warrior for about a year now with an issue where the car will throw P0171 and P0174 (lean bank 1 and 2 codes) which also is related to an occasional stumble and rough idle. After scratching my head for a long time, I popped the hood with the engine running and found a vacuum leak coming from the line where the PCV valve meets the intake manifold. The line is cracked and looked like it became deformed with age. What part can I get to replace this, is there quick remedy or do I have to go to the stealership and pay $200 for a little plastic tube. I really don't want to do any modifications of the PCV system, I'm tired of working on this car and I want to drive it just like everybody else does with their cars. Any help is greatly appreciated.
Old 12-12-2009, 02:00 PM
Trunion King
bene's Avatar
You can replace that line w/ rubber vacuum hose from any auto parts store.
Old 12-12-2009, 02:01 PM
myk
myk's Avatar
I just went to a parts store, bought the right size rubber hose and squeezed it on both ends-no more problems. At least, I think I had the same problem you do with the PCV hose.
Don't let the occasional fix or repair job turn you off, it comes with the territory...
Old 12-12-2009, 02:17 PM
eseibel67's Avatar
Dude, it doesn't work that way. Anything mechanical needs attention.
People that just "drive thier cars" are either in for a hefty repair bill or had better be on a perpetual 2 year lease program.
Old 12-12-2009, 02:42 PM
Tuffguy610's Avatar
Thats good to know that a piece of rubber hose will work. At a quick glance (it was dark out it looked like it was a special piece that had to go in there. I'll fix it in a couple days, thanks for your help guys.
Old 12-12-2009, 03:39 PM
Danny2tek's Avatar
Any piece should work, hell I replaced that little piece with a fuel type hose years ago with no issues.
Old 12-12-2009, 05:53 PM
fleetmgr's Avatar
If you live in a state requiring smog inspections similar to CA., any rubber hose won't work. It has to be bonafide smog hose or it'll fail the inspection.
Old 12-12-2009, 07:56 PM
Tuffguy610's Avatar
Man thank god I don't live in California, that stuff would p!$$ me off big time. I am 100% sure that Pennsylvania inspection won't go that deep, so I'll slap a rubber hose on it and say bye bye to the vacuum leak.
Old 12-13-2009, 03:16 AM
myk
myk's Avatar
Maybe the OP's PCV routing is different than mine, but all I had to do was replace a rubber tube that had cracked and split open because of an odd angle it was in. I can't imagine they can tell the difference between what the factory installed and what I came up with. My piece looks better actually...
Old 12-13-2009, 05:06 AM
Spartan7's Avatar
They don't care what kind of hose it is, as long as the smog **** works the way it's supposed to and it's all routed the way GM set it up.
I used fuel line hose to repair my EVAP system before.
Old 12-13-2009, 06:21 AM
fleetmgr's Avatar
When I used to live in Ca., on 2 different occasions I got shot down for not using smog hose where required. It depends on how tight the guy is doing the inspection.
The Evap can should have fuel hose on it I believe.
Quick Reply: Need advice for how to fix PCV line vacuum leak
