Sponsored by: CARiD
Front Oil leak
Old Jan 7, 2010 | 07:44 PM
DarkJuggalo's Avatar
Default Front Oil leak
I have been trying to figure out what the hell is leaking for months and just cant seem to pinpoint it, i put it up in the air and sit there and watch for 30-45 minutes and nothing, but as soon as i walk away and come back theres a drop on the ground. its driving me nuts, between it burning a small amount of oil and the leak i go through a quart every 3k miles. it is definately on the front of the motor though, just cant pinpoint it. so i bought a new oil pan gasket, and timing cover gasket with my cam kit, so i figured this should do the trick. any other spots it could leak from i should check while im there?
Old Jan 7, 2010 | 10:15 PM
RA032926's Avatar
what about your rack and p.s. lines?
Old Jan 7, 2010 | 11:06 PM
havent checked those, ill have to now lol
Old Jan 7, 2010 | 11:30 PM
98pontiac's Avatar
sounds like your front main seal. I replaced mine at 92k miles. Its behind the balancer where the crank comes through.
Old Jan 8, 2010 | 12:12 AM
car has 61k original miles
Old Jan 8, 2010 | 01:13 AM
wads97gts's Avatar
front seal is common, good luck
Old Jan 8, 2010 | 02:44 PM
ill def be checkin it
Old Jan 12, 2010 | 05:53 PM
black93camaro's Avatar
My timing cover seal also just went out last week and i only have 62k. its pretty easy and painless.
