Sponsored by: CARiD
E-brake switch location?
Old Jan 11, 2010 | 01:20 PM
LadyDriven's Avatar
Default E-brake switch location?
Tried searching, couldnt find any pictures! Does anyone have a picture of the ebrake switch location? My brake light is on
Thanks
Amanda
Old Jan 11, 2010 | 06:46 PM
nemss1's Avatar
i dont have any pictures but i can tell you where its at. removed the upper console/shifter plate.....whatever you wanna call it, and its on the shifter assembly. just look for wires running to the shifter assembly and you will see it
Old Jan 11, 2010 | 08:11 PM
BlackDuk98's Avatar
Here is a pic when I upgraded to an A3 shifter, should help you out.
Old Jan 12, 2010 | 12:25 AM
nemss1's Avatar
ladydriven, look at the pic above. see the wires going to a red plastic piece with a copper recepticle on it?
thats the E-brake switch. it does come off. i took mine off. its held on by a single hex screw
thx for the pic blackduk98. that helped me explain myself better
Old Jan 12, 2010 | 01:00 AM
99huggerorangeZ's Avatar
Thanks
Amanda
are you sure your brake fluid just isnt low??
Old Jan 12, 2010 | 09:45 AM
LadyDriven's Avatar
Yup, checked it first.
Thanks for the info!
Old Jan 12, 2010 | 12:51 PM
nemss1's Avatar
no problemo
Old Mar 8, 2010 | 02:15 PM
LadyDriven's Avatar
So, my brake fluid isnt low, what do I do now? Do I have to replace the switch? How do I test to make sure its working properly?
Old Mar 14, 2010 | 07:13 PM
LadyDriven's Avatar
Anyone???
Old Mar 14, 2010 | 07:23 PM
Anyone???
i would think you would be able to use a test light and test the switch.
