need window regulator help.
i was planning on fixing it the same way. so i made the metal plate losened the regulator. couldnt get the holes to line up and getting frustrated took out the window motor. i never secured the regulator before taking out the motor.
so heres the issue after i got the last screw out of the motor the spring in the regulator unwound and came off. on the bright side all the holes line up perfect now but thiers no tension on the spring. i think i can hook the spring back on but how many turns should i spin it to put tension on it before putting everything back together.
If you search way back for regulator and spring, you should find additional discussions
so it looks like its not a big deal it souuldnt be to hard to put the spring back on and get one turn or so of tension on it.
thanks again for the help
GM's factory service manual seems to imply that its "impossible."
