Sponsored by: CARiD
Best drive shaft loop
Old Feb 6, 2010 | 07:42 PM
muteki's Avatar
Default Best drive shaft loop
Ok, I recently installed the magnaflow 3 inch catback in my T/A. It sounds awesome, I just noticed when I hit a good bump, I hear the pipe hitting the brace under the drive shaft. I removed it, sound went away, reinstalled and it came back. So, I am certain this is the problem. I figured I might as well get a drive shaft loop if I am goinng to replace it. That being said, which brand has the best curve to allow for a bigger exhaust WITHOUT having to bang it with a hammer. Also, what are the pro and cons of a drive shaft loop that bolts around the driveshaft as to the one that the driveshaft has to be removed to install.
Old Feb 7, 2010 | 02:12 PM
fucter's Avatar
I went with the lakewood one
Old Feb 7, 2010 | 02:24 PM
tals7's Avatar
Smile
i use the bmr loop with 4in pipe and not even close to hitting.
Old Feb 7, 2010 | 02:46 PM
MYSTIC-1SC's Avatar
more input guys. Im looking at purchasing a driveshaft loop as well, and was wondering how the umi and bmr driveshaft loops fit. Also the slp loop looks pretty nice as well. Lets hear what you guys think.
Old Feb 7, 2010 | 04:23 PM
97camaross's Avatar
I have the bmr loop and like it
Old Feb 7, 2010 | 05:25 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
SLP pic
Old Feb 7, 2010 | 05:54 PM
jimmyblue's Avatar
Moderator
The good thing about the Lakewood is, you can put it
on without dropping the driveshaft. It also doesn't sit
down low like that SLP pic. I didn't have any troubles
with exhaust banging.
Old Feb 8, 2010 | 05:36 PM
MYSTIC-1SC's Avatar
thanks for the input.
Old Feb 10, 2010 | 08:04 PM
muteki's Avatar
Yes, thanks for the input. How difficult is it to drop the drive shaft? I am leaning toward BMR, since I was looking at at some of their packages anyways. Thanks for the pic on the SLP one, that really helps.
Old Feb 11, 2010 | 08:17 AM
BMR Tech's Avatar
The driveshaft is real easy to remove. Just remove the 4 bolts at the rearend and remove the U-bolts and pull the shaft out. You might need to put a little penetrating oil on the nuts but they usually come loose without much effort.
Like other mentioned our loop does provide much need clearance around the exhaust are to keep it from hitting and causing rattles.
But I will have to say that everyones car is a little different and it might require you to loosen the exhaust clamps and reposition the exhaust for optimal clearance.
A link to our driveshaft loops can be found HERE
Any other questions please ask
Old Feb 12, 2010 | 02:31 AM
muteki's Avatar
Thanks BMR tech. I'm just waiting on my commission check then I will place my order. I have to clear some credit...lol
Old Feb 12, 2010 | 08:04 AM
BMR Tech's Avatar
Sounds good.....just let me know
Old Feb 12, 2010 | 06:11 PM
monte383sbc's Avatar
bmr loop here, plenty of clearance
Old Feb 13, 2010 | 01:20 AM
muteki's Avatar
yep, I was pretty sure that was the brand to go with, just looking at the design, it looks like a full inch of clearance...not to mention, it will match perfectly when I decide to upgrade my suspension.
