My car is acting up ;(
Old 02-16-2010, 12:42 PM
59 fbody's Avatar
Unhappy My car is acting up ;(
This is my first thread and I hopei am doing it right.... My brother told me to go on here he is the one that gave me the car he is 59camaro. I am clueless about LT1 engines I noticed this week that my car started to shake a lot when i put it in reverse it shakes even more, I feel as if its going to shut off on me. Oh and if cant get any worse water is going in my car. I have a 95 camaro z28 No T top and from what i have noticed the water is not coming in from the door cuz the panels are dry and the only part that is flooding is the back of the passenger side it had been raining a lot these last few weeks and a lot of water went in my car. Can anyone help? Or have a clue what might be wrong with my car???? Thanks
Old 02-17-2010, 08:28 AM
rabbit320's Avatar
try not using pink, hard to read... where exactly is the leak? reverse vibration could be anything in the driveline...
Old 02-17-2010, 04:20 PM
59 fbody's Avatar
I wish i knew its not from the window cuz all the water is just in the back of the passenger seat i am clueless. Thanks for the reply
Old 02-17-2010, 04:31 PM
buddha845's Avatar
leak might be from the top of the rear hatch
Old 02-17-2010, 04:43 PM
59 fbody's Avatar
if its coming from the hatch wouldnt my back seats be wet too?
Old 02-25-2010, 12:03 AM
59 camaro's Avatar
ttt, any of the lt1 guys plz help my sister since i dont know jack bout lt1's..... thanks
Old 02-25-2010, 01:53 AM
...with cheese.
Armageddon's Avatar
A vacuum leak will cause the motor to shudder when you load it up by putting it in gear at idle RPM. I read your post a couple times and can't find any specific information that would help me track down your problems.
I might suggest sitting in the car and having someone hose it down while you watch for leaks.
The vibration problem will require more information to diagnose.
Old 02-25-2010, 07:39 AM
59 camaro's Avatar
thanks for the help....we dont live together so i havent had a chance too look at it in person
Old 03-05-2010, 03:32 AM
59 fbody's Avatar
Thanks
The car will start fine it will drive good for the first 10 15 min then it will start to shake quite a bit i feel as if it will shut off. Thanks for all your suggestions
