Drivers Side Door Handle is Wobbly
Not sure if the door handle problem is solved yet but I had the issue on my car. Im not sure how to fix the spring but to tighten the handle, take the door panel off, on the backside of the handle (inside the door) there will be a couple nuts. I just tightened mine up and it fixed the problem.
