p1635????
It is a 5 volt reference 1 circuit fault. The PCM uses a common 5 volt circuit as a sensor feed. This particular feed only goes to the A/C pressure sensor, EGR valve and MAP sensor. Check for loose/dirty plugs or wiring problems. It only has to do with those 3 items, wiring or the PCM.
