Sponsored by: CARiD
ABS INOP & Brake Light On
Old Mar 10, 2010 | 11:10 PM
Midnight00SS's Avatar
Arrow ABS INOP & Brake Light On
Noticed today after i put my 295/45/17 m/t street radials on my abs inop light is on with the brake light while im driving, car feels fine, what is this though?
Old Mar 10, 2010 | 11:18 PM
Breathing Fire's Avatar
Are you running the same size front and back? If not that may be the problem. Two different rotational speeds can cause the abs to disable.
Old Mar 10, 2010 | 11:23 PM
Nemesis350's Avatar
Well there's plenty of answers if you do a search. But the short version, although i'm not 100% sure, is that there are sensors on all four hubs that send feedback to control both Traction Control and ABS. The change of speed from having different sized tires on the back basically confuse those systems, and those lights come on. Apparently there's no way to FIX this (not even tune), aside from just putting the right size back on. Some would suggest disabling the abs module; i really don't know. Do a forum seach
Old Mar 10, 2010 | 11:29 PM
yea i got 275/40/17 up front and 295/40/17 in the rear which are taller, so will i hurt anything? or just wont have any abs? i thought u can retune the car with the new tire size??
Old Mar 10, 2010 | 11:37 PM
No it won't hurt anything. I have a predator and when I had different front and rear sizes I was able to program for it and I didn't lose my abs and never had a problem using the predator to do it. I have read like above that not even a tune can fix it, but it worked in my case. Now I just run the same front and back so I don't have to worry about it.
Old Mar 10, 2010 | 11:45 PM
so does the abs still work then?
Old Mar 10, 2010 | 11:46 PM
Nemesis350's Avatar
Well that's really good to know! I was just relaying what i read previously on several posts... i'm glad you shared that. I've been running staggered sizes for a couple of months now and the lights get really annoying. My brakes suck garbage anyways, so i wasn't too concerned about that.
Old Mar 10, 2010 | 11:52 PM
yea so will i lose my abs or not lol?
Old Mar 11, 2010 | 12:04 AM
Nemesis350's Avatar
You could always test it out and see... LOL sorry, i know that's not a good suggestion. My brake system sucked before this happened, so i really couldn't say with certainty.
Anyone else care to chime in?
Old Mar 11, 2010 | 12:05 AM
Rushin's Avatar
If the ABS INOP light is on, then yes, ABS will not work. Just slam on your brakes a couple times, you'll see.
Old Mar 11, 2010 | 12:12 AM
haha, im sure there has to be a way to run bigger tires back there and still have the abs too, why is the brake light on as well?
Old Mar 11, 2010 | 12:16 AM
My abs still worked when I did it. Now if it doesn't work then don't, you know, but don't just get one to fix that one problem. The predators aren't cheap. Useful, but not cheap. The only problem with them is you can only use them on 1 car at a time. But like I said before I run the same size front and back now. Still can program whee/tire size for correct speed reading tho.
Old Mar 11, 2010 | 12:20 AM
so it still worked even though ur light was on?
