Low Coolant Light
ryan
Here's a thread with a similar issue (the problem was the cap) with a lot of good discussion - but it was still the cap. https://ls1tech.com/forums/general-m...-radiator.html
When you get a new cap, I'd recommend getting one from the dealer instead of the auto parts store. If the '95 is like the '98-'02, then the GM cap has a special feature on it that protects your radiator from vacuum build up when the fluid cools down.
and if/when you do service the cooling system and fill it up with water to do a flush, be aware that you'll most likely not drain 100% of that water out so when you fill the system with antifreeze if you've premixed it at 50/50 what will really be in the system is less than that, you'll need to judge how much water you've drained out
