Sponsored by: CARiD
What's wrong with my car?
Old Apr 6, 2010 | 08:36 PM
ForumMoto's Avatar
Default What's wrong with my car?
Hey everyone so I have an interesting problem. My obd port doesn't work. I discovered this as I had a Check engine light come on and I plugged my diablosport programmer in to check and clear the code. It powers up on othercars but won't on mine. I unplugged the car battery and reset the computer, but it still doesn't work. I'm confused...any ideas what's up? Thanks all
-Jason
Old Apr 6, 2010 | 08:59 PM
fleetmgr's Avatar
Bad ECM
Old Apr 6, 2010 | 09:05 PM
ForumMoto's Avatar
Is this common? The car has 85k on it..
Old Apr 6, 2010 | 10:26 PM
fleetmgr's Avatar
Not common, but it happens.
Old Apr 6, 2010 | 10:42 PM
ForumMoto's Avatar
Now being that I can't even plug in to diagnose it, I've just got to assume that's what it is? Otherwise, I'd take it and have it diagnosed. Not trying to be dense here, just trying to make sure it is what it is
Old Apr 6, 2010 | 10:52 PM
JoeD427's Avatar
Default fuse
check the fuse before u buy an ecm. i think it runs on the same circut as the cigarette lighter and is 25 amps
Old Apr 6, 2010 | 10:58 PM
Darksol's Avatar
Originally Posted by fleetmgr
Bad ECM
WRONG!
My money is on the guy with ten posts being right. Not the guy with 900+. Check cigarette lighter. If it works something else is wrong. However I would bet the fuse is bad.
Old Apr 6, 2010 | 11:31 PM
ForumMoto's Avatar
Thanks so much guys...the cig fuse is out since it doesn't work. I'm goina replace that tommorow and see if it does the trick. You guys think that could be caused by running a high wattage bass amp, without a capacitor? My lights dimmed everytime it hit...I've since discontinued using it till I get a capicitor. Thanks
-Jason
Old Apr 7, 2010 | 08:50 AM
THE SHOP's Avatar
-Jason
NO, and it is 99% the time the cig fuse it provides power to the datalink connector.
Old Apr 8, 2010 | 02:35 AM
ForumMoto's Avatar
That's what it was Guys the cig lighter fuse...thanks so much for the help!
