how to stop metal to metal squeak?
This is an interior problem, so this might be the right place for this.
The metal hook that holds the back seat up is squeaking against the metal bolt thing it latches to (<-- technical term). What can I do to permanently stop this. I have tried relatching it, only temporary. I have used WD-40, only temporary. I would just like some ideas to stop this squeak.
Thanks,
Brian
Thanks,
Brian
Have you checked to make sure that the posts where the latch catches are fully tightened down? They screw into a rectangularly shaped nut that rides up and down, front to back, in a diagonal channel for adjustment. I'd think that if it were loose, the seat could put some force on it, sliding it around a bit. Just my $0.02.
