Sponsored by: CARiD
crank position sensor broke off
Old Apr 30, 2010 | 05:03 PM
rich Z's Avatar
Default crank position sensor broke off
The car wouldn't start and was throwing this code. Removed the starter to get to it and the sensor just pulled right off along with the mounting bolt and some of the block. Now there's a hole in the block and a small stress crack in one place. Am I looking at a new block or can this be welded?
Old Apr 30, 2010 | 05:51 PM
rich Z's Avatar
Old Apr 30, 2010 | 09:22 PM
lt1pwr1's Avatar
Did the block rust out or something? I'm trying to picture how the bolt would come out when it is threaded in unless the block rusted out. Especially without you prying on accident. Can you get a picture of it?
Old May 1, 2010 | 08:24 AM
Pocket's Avatar
Did you throw a rod?
Alum blocks dont rust, and your great grandchildren will never see a 1955 cast iron block rust through
Pieces of the block dont randomly fall off
Old May 1, 2010 | 12:14 PM
rich Z's Avatar
Ok here's something else that happened in the last couple weeks. First I had the number 8 fuel injector stuck wide open. Dumping all the fuel into the cylinder. This happened after I took the injectors off and home cleaned them using a 9 volt battery to turn them on then flushing fuel cleaner thru them. I did this before with no problem. I must have burned the coils causing it to stick wide open. I never drove the car after this happened just started it twice and turned it off. Then ordered new injectors which took a week to get. I then pulled the fuel rail to see the manifold all full of fuel on the number 8. Then I pulled the spark plug and let the gas drain. Then a few days later when i got the injectors and installed them it wouldn't crank. I then turned the crank pulley by hand and moved it a bit then it cranked but no start. Then thru the crank position code. I add oil to the cylinder before trying to crank it too to let it soak the rings since gas flushed them. Still I don't see how this has anything with the crank breaking off. I will try and post a pic. It look like it's been cranked though for a while looking at the oil around this area. It's not fresh looking more black.
Old May 1, 2010 | 12:48 PM
mwg2600's Avatar
post pics Sounds like it hydrolocked and broke
Old May 1, 2010 | 01:05 PM
rich Z's Avatar
Old May 1, 2010 | 01:06 PM
rich Z's Avatar
Click on my user name and the pic is there.
Old May 1, 2010 | 01:44 PM
Pocket's Avatar
Your engine is done for. Look at the bulge coming out. Thats a rod pushing on it
Old May 1, 2010 | 01:52 PM
rich Z's Avatar
Well time to storage because I'm broke. How much you think the car is worth with a blown motor.92k mile in fair condition. 3k maybe?
