Sponsored by: CARiD
Speedo is off , How do I fix it ?
Old May 9, 2010 | 08:31 AM
jaysan's Avatar
Originally Posted by greasemonkeysoldier
i've got this same problem as well....as has been stated before i assume this is a very common thing. mine is off by about 5 mph at lower speeds and 10-12 mph off at higher speeds (i.e. 60-70 mph) the Tach is also off. I found out it was off when i had it hooked up to HP Tuners doing some logging. so the PCM is putting out the correct mph/rpm....but my gauges aren't. How could this problem be fixed? and how would you go about recalibrating the PCM if that is the fix?
dude this is the problem I am having EXACTLY , Did HP tuners help ?
Old May 11, 2010 | 08:49 AM
ls1jorge's Avatar
try replacing speed sensor, go to autoparts store, & replace them & see what happens it shows I'm going 15mph more then the speed limit
Old Aug 12, 2010 | 11:08 AM
jaysan's Avatar
I was told on another forum and some one said I could have aftermarket gears that could be throwing off my speedo . My RPO said GU6 so 3.42 but in 6th gear at 2,000 rpm my car is doing 90mph . So does my car have bigger or smaller gears ? Plus how can a tuner figure out the gears I have because some one suggested a tuner can adjust my speedo.
Old Aug 12, 2010 | 11:42 AM
JimMueller's Avatar
Assuming you have 275/40/17 tires, a 3.42 final drive, with a 0.50 overdrive tranny gear results in 89MPH at 2000RPM. This math indicates you have a 3.42 ring & pinion.
http://www.kabamus.com/garage/gears.html
The tuner will be able to adjust the parameters to match your tire size & gearing. However I did the same thing and the speedo was still 5MPH fast at 60MPH. I think I adjusted the pulses per mile to get it closer.
Old Aug 12, 2010 | 01:02 PM
meine96ws6's Avatar
well, i wouldn't worry about 5mph.. that way your never really speeding.. mine is off about 4 mph..
Old Aug 12, 2010 | 01:23 PM
96blackta's Avatar
Sounds like it had 3.73 gears swapped in... mine was off by 5 until I tuned for the correct ratio.
Old Aug 12, 2010 | 05:25 PM
jaysan's Avatar
sorry at 90 mph my actual speed is 85 mph though and I have 275/40/17 and the rear are 315/35/17
Old Sep 21, 2010 | 01:27 PM
jaysan's Avatar
So with that I am guessing I have 3.42 gears in my rear end but the car is programmed to 3.73 's ?
What do yall think ?
Edit : I want to know because my car may have less miles that what the odometer reads .
Old Sep 21, 2010 | 08:19 PM
JimMueller's Avatar
Not sure if you can see the pinion gear this way, but it may be an alternative. Buy some replacement gear lube and the additive if required. Pull the diff cover, count the ring teeth, and count the pinion teeth, then divide ring by pinion to get your ratio. Re-seal cover and replace fluid.
Old Nov 18, 2010 | 09:50 AM
jaysan's Avatar
Speedo FIXED I took my car to a tuner and the tuner said my car hasn't been messed with . and the aftermarket wheels would not cause that big of a skew in the speedo . But long story short is was fixed by messing with the tire size.
