Sponsored by: CARiD
Speedo is off , How do I fix it ?
Old May 1, 2010 | 09:37 PM
jaysan's Avatar
Default Speedo is off , How do I fix it ?
My speedo is off by 5 mph. The gauges say I am doing seventy mph but in all reality i'm going sixty five mph. Any thoughts
Old May 1, 2010 | 09:45 PM
jaysan's Avatar
only mod is slp skip shift and borla exhaust
Old May 1, 2010 | 10:10 PM
99'CajunFirehawk157's Avatar
If you get a handheld tuner you can adjust for tires I think?
Old May 1, 2010 | 10:32 PM
jaysan's Avatar
wheels and tires stock sizes
Old May 2, 2010 | 09:42 AM
jaysan's Avatar
Could the skip shift eliminator have skewed my speedo ?
Old May 2, 2010 | 10:08 AM
Blu99T/A's Avatar
Every GM vehicle I have had has been off by at least 3mph (speedo showing faster than I was truely going).
Old May 2, 2010 | 10:58 AM
kamaa150's Avatar
if you can find someone with hptuners they can edit your speedo. what size tires are you running? smaller tires than stock will make your speedo go faster and if you have gears in the rear end, higher gears will do the same thing.
Old May 2, 2010 | 11:21 AM
jaysan's Avatar
tires are 245/45/16 and the rear is stock
Old May 2, 2010 | 06:02 PM
94lt105's Avatar
Ya, just get a handheld tuner and fix it! Never seen a car off that bad with stock tire size tho.. that kinda confuzzles me!
Vince
Old May 4, 2010 | 06:22 AM
rrwebster's Avatar
where do you find a handheld tuner? I've got the same problem on my 88 gta.
Old May 4, 2010 | 07:29 AM
greasemonkeysoldier's Avatar
i've got this same problem as well....as has been stated before i assume this is a very common thing. mine is off by about 5 mph at lower speeds and 10-12 mph off at higher speeds (i.e. 60-70 mph) the Tach is also off. I found out it was off when i had it hooked up to HP Tuners doing some logging. so the PCM is putting out the correct mph/rpm....but my gauges aren't. How could this problem be fixed? and how would you go about recalibrating the PCM if that is the fix?
Old May 4, 2010 | 10:26 AM
96blackta's Avatar
What about gears? I have 3.73's and my speedo is off by 4 mph.
Old May 4, 2010 | 08:01 PM
wssix99's Avatar
Save the manuals!
Get a portable GPS, put it in map mode and drive down a straight road. Test the car at different speeds and if you are off by 5 mph in all of them, then you just have to move the needle on the post it sits on.
Old May 5, 2010 | 05:57 AM
Michael02hawk's Avatar
This is not common at all !
These 4th generation f-bodies have very accurate speedometers.
To the original poster, did you buy the car used?
If so, they might ave swapped gears in the rear end and not re-calibrated the PCM. If thats not it, something else is wrong, hiring a qualified mechanic would be my advice.
Old May 7, 2010 | 09:39 AM
jaysan's Avatar
Should I take it to the stealership ? Yeah I bought it used from a 60 year old man
Old May 7, 2010 | 03:07 PM
wssix99's Avatar
Save the manuals!
Um - no. What do the gauge faces look like? Are they the original black ones?
Old May 8, 2010 | 08:24 AM
No reason to use a dealership, no warranty, overpriced and they are not always up to date on aftermarket parts, such as rear end gearing.
A qualified mechanic would be my advice.
Old May 8, 2010 | 08:39 AM
ULTIMATEORANGESS's Avatar
any shops near you? they can correct that for about $25-$50.
Old May 8, 2010 | 09:14 AM
JimMueller's Avatar
My PCM reported being 5MPH off compared to a GPS on a clear night. I made multiple changes to the speedo calibration through HPTuners and eventually got it within 1MPH. I wouldn't be surprised if it falsely reported slightly faster from the factory.
Old May 8, 2010 | 08:27 PM
jaysan's Avatar
yezir , and I have the stock rear end
