AC and cruise control quit working???? any ideas...
after doing some research on here, i dont know if they are related, but both quit working at the same time? no cruise control at all??? AC, well here is the story....have not checked to see if it has freon yet, the clutch is not engaging at all. jumped the sensor plug and the clutch is still not engaging??? the fuse is good, looked under the dash and all looks good wiring wise??? so if the cruise switches go bad, does that affect ac as well???
this is something funny as well.....turn the ac on, and it wont engage at all, but driving it, it will blow colder air, not COLD but colder, but gets warm again if you stop??? also read something about if the idle is crazy the ac wont work??? well my idle is not crazy but i do run an ms4 cam???
no ses light at all??? im way confused on this deal!!!! please help, thanks in advance
Don't know if it's related to the cruise control, but there are a couple AC clutch circuit codes (P0645, P1546) - neither of which will illuminate the SES light. I'd try scanning for codes.
well, pretty sure....i pulled the fuse out and looked at it and it was not burnt in two pieces???? i guess i should change it just to be 100% sure huh.....will do that today!!!!
still havent figured out the compressor issue though....jumping the plug will start the fan but not the compressor? going to check the bottom plug on the compressor itself today!!!!
any other suggestions will be greatly appreciated!!!! thanks
![Wink](https://ls1tech.com/forums/images/icons/icon12.gif)
hey there .. can you please add pics to clarify .... i test the switch wires in which they all show power availble (exept in OFF mode) what to adjust ? sorry 4 the hijack !!
I had this exact issue happen the other day. I checked all the CBs, as that seem most likely. Last night, I looked over the schematics and nothing really jumped out, other than vacuum lines for so much of this equipment.
Sure enough, right on the top front of the engine, above the belts was a. Disconnected vacuum line. I plugged it in and within three seconds of starting the engine, there was nice, cold A/C. Cruise works again, too. A confession... I’m not a mechanic, just a female airline pilot 👩🏻✈️ 🙌
Sure enough, right on the top front of the engine, above the belts was a. Disconnected vacuum line. I plugged it in and within three seconds of starting the engine, there was nice, cold A/C. Cruise works again, too. A confession... I’m not a mechanic, just a female airline pilot 👩🏻✈️ 🙌[/QUOTE]
I've been looking for months to findton answer to this could you post a pic of which vacuum line it was ?
![](https://cimg4.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1316/42a70707_0264_492c_aace_d4efdd7ab8e4_90e87f1cf6a84dc01d401b6c22e0daca67a549b8.jpeg)
This is on a 1996 Oldsmobile, but being GM, it’s all pretty much the same. Find the vacuum reserve canister and trace the vacuum line out the top. On my Olds, the canister is behind the right headlight. The parallel line is running out to vacuum powered equipment.
