car stalls
bump.. ok so i was wiggling the pcm wire harness everywhere while my dad tried to read the tech 2 and he said all the gauges started going crazy when i was doing that.. dont know if that changes anything or not..
But it sounds like a loose PCM-Engine ground. But it could be any of those wires in that harness that might be fried or frayed and rubbing other wires. If you're not getting codes, the PCM is probably fried...maybe.
Call body shops too....if the dealer doesn't give you a number. They should give you numbers of some of those guys. This guy told me that 85% of his business is body shops. I was like, "why?" He said to reset airbag codes on all makes and models and to rewire sometimes when a car gets crunched up. He said if I towed my car to the dealership for the loose ground that I had, they would have called him or one of the other few guys in Lauderdale that fix that type of stuff. He charged me $100 to rewire it all, took about 1 hour. He said the dealer would have ***-raped me for hundreds. DO NOT TAKE IT TO THE DEALER.
called.. they told me they just use this place called specmo.. they do car audio and such.. but he did tell me they don't fix pcms.. they just sell used ones or bad ones to specmo and specmo actually fixes them and resells them, the dealerships just get new ones.. i called a chevrolet dealership.. i called specmo they can fix it.. but they want 60$ an hour so eh.. im just going to wait until i get my original pcm back then if that doesn't fix it, or if i still can't get a code.. then i pretty much know its wiring and il have to have someone fix it.
thanks for the help!
Call body shops and ask who they use when they need to reset SES lights for air bag deployments.
ALSO......if you have bad wiring like a loose PCM-Engine ground wire.....and you just put a new PCM in it, you MIGHT instantly fry that new PCM too. You must fix the problem that started this mess.
i just got my new pcm and my car fired right up.. but hey the problem with that is iv had this pcm for over a year in it without problems.. i get a new 02 pcm and 1 week later i have all these problems...
I am having the same effing problem.... exactly haw you explaned it runs fine then will fall on its face all the sudden. when i let off the gas it will rev a little but when i give it gas it dies. every time i start the car it resets all my gauges and that my tuner used HPtuners and it said that i have a ground to power or something along those lines to the BCM i will check grounds tomorrow . when i swapped the motor i think i forgot the block to chisses ground. thanks for the info guys! just one more reason i love ls1tech
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
