ABS light...please help
Not sure if this is the right section... if not could a mod please move it.
I have a 2000 camaro SS, and my abs inop light is on. I was told running a different front and rear tire diameter would cause this? Is this true? and would this also cause my brake and service vehicle light to be on??
Thanks for any help
Thanks for any help
To pull codes for the abs light you need a scanner that is capable of reading them. Also check your third brake light. On my old camaro I had An abs inop light on and on my third brake light bulbs were out and I replaced it and it went off temporarily. A few weeks later it turned back on and turns out my whole abs system had to be replaced. Hopefully yours is not the case.
