Ticking Noise around 2000 RPM
Do you have gutted cats ? I gutted mines and it does the same ticking sound. Possibly could be parts of the inside of the cats rattling around in the exhaust. That's what I believe the sound from my car is. You can hear it loud inside the car and around 2k Rpm you can really hear it.
I had a buddy of mine suggest that it might be the very top of the rod being bent, not seating right in the rocker arm or whatever.
I'd try hooking up a live scanner and watch the timing when you hear the noise. My WS6 has a weird tap around 2k and its actually pinging I'm hearing. Sounds like the engine tapping but when I put the scanner on it and drive it I can see the timing is at 36+ every time it starts to tap and if I push on the throttle a little harder the timing drops off and the tap is gone. Only does this in hotter weather.
I don't think my timings off, I just wanna know if any of the people that posted earlier found what was making that noise, a lsx builder told Me it's a bearing, master techs tell me lifter.. idk if should waste money on head gaskets and head bolts or start saving for a motor..
Here is an example of the sound I am interested in knowing its cause, www.youtube.com/watch?v=BcRv9px135o.
From time 0:09 to 0:12, if you can ignore the low frequency hum of the exhaust as well as the hiss of the air being drawn into the carburetor, you may be able to hear the clacking/knocking sound.
