Clutch sticks to the floor loud clunk and grinding sound
Clutch petal sticks a little wont engage so wont go in gear while running but does off and loud grind/clunch when it drove a few hundred feet pulled off slave and found metal shavings. What needs replaced? I drove it to park safe in second gear and it goes in all the gears did the clutch tear up or what else could the shavings be from?
Captain Double Post
I kinda have the same problems you do mine will drive fine if I'm just doing normal driving as soon as I start getting on it my clutch goes to the floor. When its in gear and I accelerate fast the clutch pedal goes down to a half clutch pedal. I need to replace the clutch master and slave cylinder mine also cluncks when I take off to hard
Captain Double Post
