gonna die at an early age over this car... fml
Loading up is *kind of like a small back fire almost.. You are giving it has and it sounds kind of like a gurgling effect. Best way I know to explain it. No burns or arcing on which wire?
ok, The sputtering definitely doesn't depend on rpm range, i walked the rpm in first gear all the way up to 4300, and punch it and all it did was shake back and forth. i tried right after engaging in first, and it bogged. my rear end is popping unless thats my exhaust banging (dumps). will getting a different maf affect the tuning? i've heard yes and no. i have fixed that spark plug issue btw. im definitely going with the vette o2s but i'm just so sick of this mess
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Get the o2s tomorrow.. That doesn't take 15-20 minutes tops to do if you take your time and have a beer in between doing the passenger and driver side. The difference will be noticeable immediately.
If that doesn't work, get a maf.. Again, 5 minute job tops with the simplest of tools.
lol, i'm at the point where i dont mind replacing them both for the peace of mind you know, lol. i hope my tuner can work with the new maf. do you think it will be worth getting the slp maf? or a parts store maf will do? i'm going to buy the parts tomorrow during lunch and put them on when i get home. thanks so much you guys for the help. i will keep you posted.
It should be 10Xs easier for your tuner to tune your car with a good MAF as opposed to a bad MAF.
Although, if you had a bad MAF or o2s, your tuner should have known this and told you to replace them.
haha, yep, we ran into one issue, i went lean after 4300 on each run. We figured it was the pump, so we replaced it. We kept the fuel almost 12.8- 13.2 the entire way through the gear after the new fuel pump.
i hate the fact that the car never acted up on the dyno at all. it waits until i sit in it. and i babied it home each time.
I will go with a stock maf. i'm surprised no one has mentioned to me about a camshaft postion sensor. I'm glad, because it's a bitch to get to.
ok,now i've checked the lengths of the vette plugs, and they don't have any longer than 12.2. Which is the same size as the one's for the t/a. But the t/a has some that are 16.4" and 22" or so. Shouldn't i be going for those to get the longer length?
#33
$43.00, I think this is the ome with the long wires.
http://www.amazon.com/Denso-234-4087...7781431&sr=8-1
www.rockauto.com has them for $39.00 each.
#36
i think that's $43 just for the sensor itself. no wires. the bosch oxygen sensors has a 21.6 in. wire. : http://www.autozone.com/autozone/par...065_1784_98501
#39
Amazon and Rockauto.....those prices are with the long wire. Bennett Auto also sells them cheap...with the wires. I have LT's and the wires are plenty long for me with the Densos, I have to fold and zip-tie the extra wire to the frame.
Call to make sure how long the wires are though, if you go with Amazon or rockauto.........
#40
Runs great now after i replaced with a new extention and o2 sensor
