Sponsored by: CARiD
any tip to keep the header bolt coming loose ?
Old Jul 24, 2010 | 05:31 PM
killagt's Avatar
Default any tip to keep the header bolt coming loose ?
Im going under the car again to tight the header bolt, that connect to Y pipe. Any one have any tip to keep those bolt coming loose ? red threat lock ?
Old Jul 24, 2010 | 11:55 PM
LS-1Z28's Avatar
lock washers? thread lock will help too...
Old Jul 25, 2010 | 03:53 PM
meine96ws6's Avatar
i'm thinking the constant vibration is the culprit.. i would use the thread lock first..
Old Jul 26, 2010 | 12:24 AM
killagt's Avatar
imma put in some red threat lock tomorrow, if it still dont work, imma fking weld it. any one did this ? weld the header to Y pipe ?
Old Jul 26, 2010 | 12:26 AM
HotSilverBird's Avatar
ahhhhummm http://marylandspeed.com/stage-8-loc...00-p-1006.html
Old Jul 26, 2010 | 01:21 AM
killagt's Avatar
Originally Posted by HotSilverBird
god dam for the price.
Old Jul 26, 2010 | 01:39 PM
LS6427's Avatar
Aircraft safety wire.
Old Jul 26, 2010 | 06:34 PM
LS-1Z28's Avatar
**** those
those e clips are the worst things to take off
I'm looking to get these but they're a little more expensive. (If you've ever taken off those e-clips this is a great deal...)
Percy's Split Lock Friction Lock Header Bolts (bottom of page)
http://www.speedinc.com/catagory.cfm?catagory=Exhaust
Old Jul 26, 2010 | 06:42 PM
46Coupe's Avatar
I have had good success if the split lock header bolts. Not sure if they have them for LS1 engines though. They basically are cut in an X and have an allen screw that splays them out after you torque them down. Rock solid for me on my big block car.
*edit*
Here they are for LS1
http://www.summitracing.com/parts/PHP-21008/
Old Jul 26, 2010 | 06:51 PM
LS-1Z28's Avatar
*edit*
found them for cheaper... not sure what's the difference other than they are black.
http://www.summitracing.com/parts/PH...ize|5.7L%2f350
Old Jul 27, 2010 | 11:10 AM
LS14EVR's Avatar
This is just coming from a newb, but aren't what you guys suggesting the OP use for the attachment of the header to the head? Isn't the OP having issue with the bolts that hold the Ypipe to the headers. Probably flange mount instead of slip joint with clamp. This is just what I'm reading. But could be wrong.
Old Mar 13, 2012 | 03:41 PM
3YLSYKR's Avatar
Just use stock bolts with loctite on them and you wont have an issue and saves you money.
Old Mar 13, 2012 | 05:21 PM
great421's Avatar
Nord-Locks are (also) expensive, but they work.
http://www.nord-lock.com/default.asp?url=2.16.37
Old Mar 13, 2012 | 06:43 PM
bayer-z28's Avatar
^ I ordered a set of Breslin locking bolts when I did my headers in 04, but they got lost in the shuffle and never got installed.
It's $34..... I blew $90 on locker bolts. back in 04, they were pretty pricey.. back when LS stuff was still pretty expensive.
