Sponsored by: CARiD
A/c
Old Aug 9, 2010 | 07:20 PM
wm2002Z28's Avatar
Default A/c
Wondering why for some reason my a/c won't work when I'm in the direct sun light it won't blow cold air. But when I'm under some shade it will work ?
Old Aug 9, 2010 | 07:28 PM
wm2002Z28's Avatar
Also when it does turn on you can smell like humid air like the smell right before it starts to rain
Old Aug 9, 2010 | 08:40 PM
LS6427's Avatar
Thats the wierdest thing I've ever heard.
Old Aug 9, 2010 | 08:46 PM
wm2002Z28's Avatar
I know its weird. Maybe its the compressor
Old Aug 9, 2010 | 09:01 PM
LS6427's Avatar
All I can say is maybe your condensor needs to come out and get a professional cleaning by a radiator shop.
Old Aug 9, 2010 | 10:44 PM
fleetmgr's Avatar
If it's smelling humid, I'd check the evaporator drain to make sure that it's draining. The evap box may be retaining moisture.
Old Aug 9, 2010 | 11:32 PM
BOA279's Avatar
I have to agree with him. I cant image anything else playing a part with your "direct sunlight" problem. In direct sunlight maybe your condenser reaches a temperature where not enough heat can be remove from the r134 to condense it into a liquid but in the shade it can. Check your fans also but clean the condenser.
Old Aug 10, 2010 | 09:06 PM
slow's Avatar
low charge and dirty condensor would be my guess.
Do you have vent temps when this happens, I would assume your system is just very weak due to the low charge (or damaged compressor) and is ok in low heat load situations, but the direct sun adds too much heatload for the system to cool.
have the system discharged and charged with 1.5# and measure the vent temps and pressures.
Ryan
Old Aug 10, 2010 | 11:49 PM
wm2002Z28's Avatar
Thanks everyone for your info
