Sponsored by: CARiD
Squeaky shocks?
Old Sep 6, 2010 | 12:09 PM
CsickSurfer's Avatar
Default Squeaky shocks?
i have a daily driver 01 z28 nothin special done to it.. my shocks are squeaking a lot and it drives me nuts! its pretty embarrasing too. anybody know what i need to do to fix it?
Old Sep 6, 2010 | 12:19 PM
AxisOfOil's Avatar
Replace them.
Old Sep 6, 2010 | 12:21 PM
thanks do you have any advice on good ones to purchase?
Old Sep 6, 2010 | 12:22 PM
therealcreeper's Avatar
are you sure it's the shocks that are squeaking? a lot of people fail to realize that they are not the only piece of suspension that move
Old Sep 6, 2010 | 12:28 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
It's very likely the rear lower control arm bushings that are making the noise. I would inspect those first.
But new shocks can't hurt either.
well thats the thing im not sure it may be the bushings or something. im not to experienced with cars yet
Old Sep 6, 2010 | 12:44 PM
98TAjwh's Avatar
friend of mine had some squeaking goin on with his car. he sprayed some pb blaster on the control arm bushings and it went away. i'd try this before anything else.
Old Sep 6, 2010 | 01:03 PM
z28DC's Avatar
My lt1 does the same thing, I just spray it every couple weeks.
Old Sep 6, 2010 | 01:05 PM
99huggerorangeZ's Avatar
also check your swaybar bushings
Old Sep 6, 2010 | 01:14 PM
Young Maro's Avatar
Check all your bushings first. I wouldn't use PB Blaster as it is a penetrating oil, but spray all your bushings / endlinks with WD40 or similar and report back. Shocks normally don't really squeek even when they are bad.
Any oil leaking out from the shocks/struts?
Old Sep 6, 2010 | 01:55 PM
JD_AMG's Avatar
Search the general maintenance section:
https://ls1tech.com/forums/general-m...e-repairs-102/
It could be a the brake line bracket attached to the rear axle, its known to squeek. Also could be various bushings as mentioned already.
Regardless you should replace your factory shocks anyway with some that have better valving, you will get better ride quality, better handling and better feel. The factory shocks are the weakest link on these cars by FAR.
This would be a bare minimum:
http://www.stranoparts.com/partdetai...D=20&ModelID=7
ULTIMATEORANGESS's Avatar
is it coming from one area?
i had my exhaust bushings replaced and any squeaks i had went away.
