Windshield Wiper Sprayers aren't working
step one
I replaced the fluid pump, pretty easy to change. not the problem
Check to see if sprayers/hoses are clogged. not the problem however i discovered that the sprayers aren't even connected to the hose from the pump.
Check under the car to see if that's where the fluid was spraying. nope
Has to be the electrical conection in the column/blinker.
My solution, as i don't want to mess with the column and figuring out the switch, is to run a new power wire to a momentary button switch that is wired to the accy in the fuse block on the left side of the dash. I'll mount the switch where the fog light is, and press the button when i need a spritz.
Does this seem feasible or am I making a bigger deal than I need to?
Also what kind of mess will have trying to take off the wiper cowl to hook the nozel back up?
thanks for the help!
listen for it under the hood if not then you know it's electrical problem
my passenger side won't spray for some reason I need to look into it more
I'd start by jumping the pump to the battery and see if you can get it to work. Never hear of a problem inside the car when this happens. Almost always a line or nozzle, etc.
How do you know the lines are not clogged?
The pump is brand new so I know that its electrical.
I have no idea how i'm gonna trace the problem in the wire. The bundle is barried. Does the wire remain red all the way to the switch on the blinnker arm?
If its a red wire coming from the switch I just splice it and run a new power wire and see if that works.
Thanks for the help guys! I'm really glad I didn't put a switch in it.
